in diode mode at 200ohm settings on the first GE output I get 0.544 one way and it just shows "1" the other way, which I am guessing actually means nothing on this multimeter which doesn't have a manual with it.
I did the following, and the pattern appears to hold true for this unit. I am supposing this means this output transistor is actually doing the intended one way operation. "Lets say you have found that you have a NPN transistor, and have identified the base, emitter, and collector. Set your meter for diode test, and place the positive lead on the base. Place the negative lead on the emitter. You should read a diode drop voltage of about 0.45 to 0.65V. Now place the negative lead on the collector. You again should read a diode drop of about 0.45 to 0.65V (these values are not written in stone...the 0.45 to 0.65V is the most common range however). Now place the negative lead on the base, and the positive on the emitter (called 'reverse biasing'). There should be no conduction. Now move the positive to the collector, and again, there should be no conduction. Lastly, move the negative to the emitter. Again, there should be nothing."
