- Jan 14, 2011
- Gillette, Wyo.
Thank you for finally posting sir! Will qwe see your build in a thread?
I saw that too, probably a few of the amps have them installed
What were they trying to accomplish in particular?
Common in PA setups?
The problem I find is marring the new with old. I have option of either balance or unbalanced out puts off my preamp. There is 8 db difference in line level between the two. I also and going to try a processor for crossing over the pre into three frequencies and then feed those into three amps. With the processor working best , lowest THD, in balanced output I need to reduce the input level to the Phase Linear with either transformers or a opamp setup. I do not know how much noise the opamps would add. The ones you have may be very dirty but they could be as easily be very clean. You could test them out with your gear for fun or trash them I guess.
Can you let me know on the group buy for caps. Please PM me how to get in.
So you are going through an electronic crossover.....that should have level controls for the outs to the amps....correct?
Looking forward to your results. What do you have for equipment? Will you be able to measure these changes?
Dude , what you have is nothing to sneeze at. It's all good stuff. A good PC based analyzer is Daqarta, check that out.....very handy.
I agree a fella should be able to hear a 1-1/2 db change....gonna be interesting...keep us in the loop. What's your name? grapplesaw is a lot to type evertime a salutation is in order...
Glen
From north of the 49th
Glen
49th Parallel or 49th State? Welcome Glen!
