- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
This morning, I thought the best thing to do first would be tightening the terminal screws that still had the wires inserted. Starting with the leftmost blue wire going to the AC spot, I manipulated the board a little to hold it while using the screw driver, but that movement cause all the remaining wires (except the blue one) to pop out.
At the moment, there is:
one white wire coming from the topside of the back pane
a red wire coming from the topside of the back pane
two black wires contained in heat shrink running left to right along the amplifier's topside
and a second white wire coming up from the bottom
that have become detached.
Rather than guess which goes where, Jerry, can you please advise which wire goes to what terminal?
I should have labeled them but was not expecting them all to detach. That wire is pretty stiff stuff.
View attachment 17076 View attachment 17077
Keep that blue wire where it is on the AC leftmost terminal. It's paired white goes to GND next to it.
Then the two blacks go to the two GNDs above . if looking at the pic above and assuming the leftmost is #1, that would be the two GND terminals to the right (the white that is paired with the blue goes to the leftmost GND). Sidenote - those two GND connections are for the actual speaker left (LF) and right (RT) outputs, with....
Finally, the RED to the RT terminal, WHITE to LF.
The "tweak" was this... the diodes were relocated to right off the transformer AC wiring (so that it is DC going across the chassis). Then the diode that was connected via the leftmost AC terminal was bypassed with a jumper, allowing DC to pass directly through and onto the DCP circuit.
