- Jan 14, 2011
- Gillette, Wyo.
Ok Gary, sounds good...
It's on it's way but unfortunately will take 7 to 10 days, say Canada Post.
In your experience, have there been different colour lenses on 700B meters? Somewhere on this site, someone posted about meter lens colour but maybe it was re PL400's. If they have known to have been different, maybe wait until the one I sent gets to you and swap lenses?
I can't speak for Jer, but I'm glad you appreciate everything, that's why we do it. Thought you might like the Guava. It's been my favorite for all day/everyday....
Sure glad it made it there with not too much happenin'.. whew. Now you can get to listenin!Lee, sorry for so many PM's about the intermittent left channel. I know I would get tired of hearing from me so often.
I am sure you are right about it being the Protection Relay Board since tapping it (as I mentioned) brings the channel back temporarily as does increasing the signal level going into the amplifier. Not sure of the significance, but that topmost relay being warmer than the other one below seemed suspicious.
You suggested to bypass it but I'm not exactly sure how to do that. Since detaching the wires from it looks like just loosening set screws, are you able to say where the board came from? My thought was to contact that supplier, order a replacement board and just replace it. Was it from Watts Abundant? There's a board on their site that looks very much like this one.
Fitz, thanks for the offer and I see that you and I must live close to each other and if necessary, I would gladly accept your offer. I'll know better after the following....
Nav, you may have caused me to discover the problem by asking for close up pictures of the board. After taking the first one, I flipped the board over for a shot of the topside and doing so caused two wires to pop out of the terminal block. The amp did take a tumble on the trip home so maybe the impact loosened a connection or two enough to create intermittent contact.
I've been awake for 19 hours so am going to bed now but will reconnect those wires and snug up all the set screws in the morning. Must examine picture #1 to see which wire goes where and hopefully get them right.
Are you able to advise? Lately, I'm not trusting my judgement concerning things electronic.
View attachment 17073View attachment 17074View attachment 17075
