JustMike
Wow Lee... Your kicking some ass there !!!! Now I'm dragging ass... I just dont know what to do... It will be Sat night before I can get back to my work. My next step is spraying the horns. Then .... I think I have pretty much decided to raise the top of the horn box ! Then I think I'm going to order Veneer and do all the wood that ya can see... Mainly the front and top ! Trying to find a good place to get Veneer now... Hint ... Hint... Anybody ????
Hi Kevin.
I have been following your project. Looking good .
I have used a a veneer from these guys.
http://www.veneersupplies.com/categories/Veneer__Products/Peel__&__Stick__Veneer/
They have just about every wood species available. The type with the "sticky back" is probably the easy way.
Check them out, lots of info there.
