He's right...clicking on his ID then latest posts showed 368 posts but that also wasn't true as not only did it keep CHANGING but the Go To function wasn't working for ANY page, even ones that should be populated.
I finally ended up with just 275 posts.
Now Bob, if you are trying to go back to post #1, you are too late. That list is usually cut off after X posts or a time period to save the DB of this software from playing with Green Day at the old asylum (Brain Stew).
If you want to find your posts in particular at this time you will have to recall a subject, thread name or other keywords to search from the top bar window (below our logo).
For SOME consolation, we have our search working much better than some vB platforms can muster.
ONE THING you may not have noticed...
Look up at that top navigation bar and find Quick Links, get the drop down menu and select Subscribed Threads. You may not have realized that, unless you unchecked that, all of the threads you replied to or started you SUBSCRIBED TO, even if you didn't check the box to be notified of new posts.
This is a feature of vB that can be handy...now you might have a list that's several pages long (in my case 31) and ALL of my subscriptions are listed clear back to 2012 with some 2011 posts that I responded to by Larry back in the daze.
TRY THAT and see if it helps...the other problem has plagued vB seemingly forever, and I've used forums with it back to the beginning IIRC.
