Jer!!!!! My stuff is not there
eminence1963
My stuff is not there since this BB computer upgrade. Any ideas?:shock:
eminence1963
Can you be a little more specific? What is stuff? and what is BB?
BB is Bulletin Board..
Under Forums.... My Stuff.... Scroll up a tad you should see it.
There is nothing there saying I started a Thread or My Post are there. Their there, but links are not. Also my pics are no longer there in the albums portion either.
This the message I get
Web Police
Bloomington, MN
Moderate in Moderation
Jer will have to look into it, as it is not an option or feature that I ever used. I have checked and my albums are still intact. Strange, but I suppose with any upgrade there are always issues.
He's right...clicking on his ID then latest posts showed 368 posts but that also wasn't true as not only did it keep CHANGING but the Go To function wasn't working for ANY page, even ones that should be populated.
I finally ended up with just 275 posts.
Now Bob, if you are trying to go back to post #1, you are too late. That list is usually cut off after X posts or a time period to save the DB of this software from playing with Green Day at the old asylum (Brain Stew).
If you want to find your posts in particular at this time you will have to recall a subject, thread name or other keywords to search from the top bar window (below our logo).
For SOME consolation, we have our search working much better than some vB platforms can muster.
ONE THING you may not have noticed...
Look up at that top navigation bar and find Quick Links, get the drop down menu and select Subscribed Threads. You may not have realized that, unless you unchecked that, all of the threads you replied to or started you SUBSCRIBED TO, even if you didn't check the box to be notified of new posts.
This is a feature of vB that can be handy...now you might have a list that's several pages long (in my case 31) and ALL of my subscriptions are listed clear back to 2012 with some 2011 posts that I responded to by Larry back in the daze.
TRY THAT and see if it helps...the other problem has plagued vB seemingly forever, and I've used forums with it back to the beginning IIRC.
Web Police
Bloomington, MN
Maybe Jer can decipher and fix these issues too?
Warning: Declaration of vBForum_Item_SocialGroupMessage::getLoadQuery() should be compatible with that of vB_Model::getLoadQuery() in ..../packages/vbforum/item/socialgroupmessage.php on line 261
Warning: Declaration of vBForum_Item_SocialGroupDiscussion::getLoadQuery() should be compatible with that of vB_Model::getLoadQuery() in ..../packages/vbforum/item/socialgroupdiscussion.php on line 337
I've seen messages like that as well but they tend to get lost at the top in the Cool Ice skin and then the software takes you to the last post.
Is that about Personal Messaging?
eminence1963
All is better at the OK corral.:blob:
Wasn't bitching about the problems just an observation on my part:mrgreen:
Thanks Jer:glasses8:
