 - Jun 11, 2010
 - Powhatan, Virginia, United States
 - WassupYa Mang?
With red to fuse holder black to bus bar - 0 OL
With black to fuse holder red to bus bar - an unsteady 51 K Ohms.
Try the measurements at the points in the pic above... you will be taking FOUR measurements, reversing the leads between each point above and ground..
positive lead.. positive rail.. negative lead ground
negative lead... positive rail.. positive lead ground
positive lead .. negative rail... negative lead ground
negative lead.. negative rail.. positive lead ground
One FINAL thing... for each of the four measurements above, and the leads in the same position, measure the DC volts FIRST. If you see ANY of these voltage measurements exceed even a quarter of a volt, STOP and let us know.
