62vauxhall
Southwest Kootenays BC
Left Q4
B: + 8.88 volts DC
Left Q5
B: -61.20 vots DC (minus)
Right Q4
B: +24.45 volts DC
Right Q5
B: -61.1 volts DC (minus)
Check voltage on each side of R8 on the right channel then compare to the left channel..
62vauxhall
Left R8
9.93 volts AD and 61.5 volts DC
Right R8
25.64 volts DC and 62 volts DC
Just had a mishap. Looks like the trace from B+ touched ground and sparked. Unplugged the amplifier ASAP and moved board out of the way. Plugged the amp in again and smoked (literally) Left channel R2.
Power the amp down, bleed the big caps and check Q1 in that channel. Going to bed Gary, wde'll pick up where wew left off...
62vauxhall
Did you check fuses?
Yes, immediately after it shorted.
R2 is a 56 Ohm which I don't have so will leave soon to get a replacement, store opens in 1 1/2 hours. Unfortunately about a two hour round trip with morning traffic.
Odd that Left channel R2 is 56 Ohms and Right channel R2 is 2.7 Ohms.
62vauxhall
Is this you, Gary?
No, that's not me.
This is:
I see I was not the only one to get hardware signed. Whoever that is has an amplifier that weighs considerably less than a 700B. All I wanted to carry was the face plate. I brought my own Sharpie and waited outside until he got there.
Should have waited maybe until he started using gold inK - might have been a bit more aesthetic.
Phase Linear 700B signed faceplate 1.jpg Phase Linear 700B signed faceplate 2.jpg Phase Linear 700B signed faceplate 3.jpg Phase Linear 700B signed faceplate 4.jpg
That's one of the first questions I'm goung to ask Bob....Ed has old me a story on that. Seems Bob was putzing around one day and suddenly shut down the line and said R2R was going to be 56ohm instead of 2.7ohm because it sounded better....
Thanks Gary, nice to put a face to the typin....
Could be your brother though...
Not that critical, anuyhing between 2 and 56 is fine....3.3, 5.6, 10, 12, 15, 18, 20, 22, anything....
