Gary, ya didn't need to do all those measurements, just the 3 per transistor. Pull the resistor off the output jacks, sorry I didn't mention that as I said "in this configuration"....what I wanted you to do is the standard 3 jct test for the NPN's on the NPN's, and the standard 3 jct test for the PNP's on the PNP's.......In circuit on Q5, Q7, and Q10 you will get some other reading which are the interactions with other components....we will address thenm later if there are readings that shouldn't be there.
The standard NPN test is positive on base, PNP negative on base....leave the base lead on the base and toggle to the emitter, then the collector. Run through those and tell me what ya get....
