Kev's "Cobble Together a Good 3000 PL Preamp" thread...
kevin
Forum Veteran and Hillbilly
Wise VA
Hmm.. how about I just finish it up and ship it out.. TODAY??? :glasses8:
Obviously this doesn't do it justice, but I will tell you I am tempted to send you MINE and keep this one, LOL. Nah I wouldn't do that to ya, Kev. Anywhoo... so I figured out where the issue was... the old saying "walks like a duck, talks like a duck, must BE a duck" applied - Damn if those standoffs were not LOOSE, and those provide the main chassis ground to the power supply!
I knew I wasn't nuts... this pre DID sound good a few posts back, so it was likely that the ground contact was "just" enough.. but then when it broke contact, that's where the buzz came back.
I will tighten the shit out of 'em when I get it back together tonight, then after a few hours of listening OFF IT GOES!!
<IFRAME height=360 src="//www.youtube.com/embed/SjU2q_j579c?feature=player_detailpage" frameBorder=0 width=640 allowfullscreen></IFRAME>
No wonder .... All I could here was noise... That thing sounded terrible... You will never get all that noise out of that thing Jer !!!! .... Wait a min.... Was that the music ?????? LMAO !!!!!!! You mean its supposed to sound like that ???? OK... So now all I gotta do is change the CD ..... I THINK I CAN HANDLE THAT JER !!!!!!
jbeckva
Admin/Server Dude MAA Guy
WassupYa Mang?
Ooops.. did I need to put on some Lawrence Welk for ya?? Maybe some errr.. Elvis?? :laughing1::mrgreen:
jbeckva
WassupYa Mang?
Ok, sent you the bulletin, Joe. Let me know what you think... remember I am using the LME49740's instead of the TL074's they specify, if it makes a diff?
Also hmm... doesn't that make the buffer amp have an increase in gain? Just thinking... my own may already have it (gotta look), as it sure seems "hotter" than other preamps I have tried out.
jbeckva
WassupYa Mang?
Jer any time you attenuate signals followed by more amplification to compensate for that attenuation you introduce opportunities for noise.
I'd say more thank likely no.
Well then:
C242 from 0.22uF to 0.33uF or greater, non polar
R260 from 1M to 100K
R257 from 100 to 0
C241 from 33p to 180p
R250 from 20K to 100
R258 from 20K to 16.5K
All resistors from carbon film to metal film
The same applies for the 100 series of parts too Jer. I just listed the 200 series channel.
jbeckva
WassupYa Mang?
Well then:
R257 from 100 to 0
Ahh, I can see why you asked about the mono switch (going from 20K to 100 on R250/150). Leave R156/256 at 1.1K?
jbeckva
WassupYa Mang?
Unless I mentioned it specifically, leave as is except change to metal film (lower noise)
Just making sure you know I have the 1.1K right now (I have not done the mod from the bulletin, which would change it to 1.8K instead).
For C142/242 (coupling from the volume control to the non inverting input)... should that be a "fancy" dayton/solen/jantzen kind of cap or is a standard wima/etc family ok there?
It does not get any fancier than Wima Jer. Those are the best caps on the planet...
jbeckva
WassupYa Mang?
Ok, order done n sent... We'll see how it goes! Ordered the above and any other resistor in the main buffer amp circuit. If it does "good" we can look at the tone control circuits next...
Thanks so much, Joe! I want Kev to do cartwheels when he hears this.. hehe.
kevin
Wise VA
Now why would you want to fall flat on my ass ????
That should move it in the right direction Jer. There may be other contributors within the pre that are contributors that we can tackle one at a time.
Getting rid of that megohm input impedance into that amp will go a fair distance to your goal.
jbeckva
WassupYa Mang?
Thanks again. Hey... by chance have you figured out what the overall gain would be? Would it be less or more than it is now?
Nominally the same. The elimination of attenuation increases gain. The change from 20K to 16.5K in the R feedback compensates for that and reduces the downstream amplification.
Any time you can decrease amp gain, you reduce amplified noise.
