- Nov 3, 2013
- San Antonio, Tx
- I love the sound of WOPL in the morning
So does this mean the new OP AMP is fried? I was looking over the unit and it looks like there are two jumper wires providing B+ and B- to the new OP AMP. I figure this could be a spot to introduce something to lower the voltage the OP AMP sees.
In lowering the voltage is it better to use a diode or resistors? Based on my reading I found that diodes appear to be better at maintaining consistent voltage.
This would also leave the other OP AMP's exposed to the higher voltage. One has two resistors running B+/- so I figure those could be changed but the OP AMP closest to the transformer has a direct trace providing the
+/- so I can't really see how I can reduce that one unless I can change the diodes in the bridge rectifier to provide a voltage closer to 15V.
