Tinkered around a little more with the preamp. Measured the B+/B- off the the main caps and I am running around +/-19V. Tracing it back to the IC AMP (Now with brown dog adapter) I get the same voltage at pins 7 and 11 so that checks out well. I also get voltage out of pins 4 and 12 and from what I gather isn't supposed to happen. The voltage initially starts around 900mV and slowly increases until I turn the unit off and it starts all over. This voltage is also the same at the tone control switch and connects to most the tone controls so it is difficult to trace where the leakage may be happening
I checked the other IC AMPs and all the pins are 0V except B+/-. So at this point I am thinking I should probably remove the new IC AMP and re-install the old one to see if it rectifies the voltage issue. The only other thing I can think of is maybe a cold solder joint somewhere I can't see or one of the WIMA caps I installed is bad or possibly the wrong value (I triple check everything).
Do you think I am heading in the right direction with swapping out the IC AMP
