Max output...
Max output...
What would change if you did it at a 4 ohm load??
The wattage would go over 700 per. I was testing a WOPL into 4 ohms once and hit 723 before I started taking out fuses..
Signal to noise ratio,,,,
I think the AP has to go back to Beaverton. I'm showing 1.9 to 2.2millivolts on residual noise, my Fluke measures it at .4mv. It is a VERY QUIET amp at idle, that figure does not represent reality. Distortion figures are not what I would call what we are used to seeing...
I don't think the Fluke can read all the noise up to 80K hz...
  That put's you in the hot seat - but I know you don't mind a bit.  We love you man!  Did I say that out loud?
