Lee, what was the indication that made you say you lost bias on one of the channels? I'm thinking that we could put together a pretty good troubleshooting guide based on our experiences. Using the military approach of 1) checking for good input, 2) verifying bad/no output, 3) selecting a point halfway through the circuit and checking for signal, 4) if found, move downstream halfway again, if not found, move back upstream halfway until found, etc. Separate section for PS issues, and bias and protection issues. Joe's boards are good enough that we could put some voltage readings at selected critical points (with Joe's approval, of course) on a known good board to make voltage checks. Then, if the voltage is low/high go "here" or replace "part" and we could have a consistent set-up (maybe using your ATS-1 parameters) like 1kHz .5V sine wave input, 8 Ohm load on output, etc.
Maybe that is a new thread?
Mark
Mark
