I think Ed you need to write a procedure in order to get reliable comparative data. I for one do not publish much data because what I use for equipment may differ with others. Also types of Leeds and lengths, voltage of main supply, supply distortion Etc. etc. differ for all of us. When I test I compare to my last units built. this is the best can do without exact steps.
I have done extensive research on Bais. There is much information on amperage required to turn on the devices but a true explanation on correct voltage setting is very allusive.
I am very interested in this subject. With dual rail voltage amps your bias varies quite a bit from high to low rail. I am now making an intendant fixed voltage supply to power the control board regardless of rail voltage which will supply constant bias voltage regardless of rail voltages.
Any further information would help all of us.
