- Jan 14, 2011
- Gillette, Wyo.
The big question is.....what voltage and amperage is Navo's Avvie....
Yea those CFM eyes will get it goin .... Shes Incindary
First off there are 6v/12v trickle chargers, generally marketed for motorcycle batteries.
BUT this doesn't address the major failure mode for batteries that sit for long periods of time - sulphation.
There seem to be two types of circuits they use
a. fast high voltage pulses of limited energy that are enough of a voltage that it passes the threshold for the sulphate poisoning
b. pulses again, of a lower voltage BUT having a 3 megahertz (approx) frequency that hits the resonance of the sulphate molecule and busts it up.
There are things called solargizers (look it up and read their marketing material) that are connected TO the battery and their aim is not to top off the battery, but rather prevent sulphation - with a secondary effect of maintaining the state of charge.
I would point at some products - but I don't know if you are trying to do this on the cheap.
I am in a similar situation - I have 12v sump pump back up batteries that either go flat just when they are needed, or on the float maintainer / charger end up sulphated and unable to deliver when needed. Thus i need to come up with the right mix for the system.I am still researching it, and some added urgency has intruded since I discovered two marine deep cycle batteries in my Dad's basement. THEY if not terminally sulphated or dead will be the basis of the system.
If those two batteries are useless, I am going to get an Optima spiral cell marine deep cycle battery, and one heck of an expensive charger, maintainer and anti-sulphation pulser system. My car has an Optima spiral cell battery and it has lasted over TWICE (10 years and counting!!) as long as any other battery I have ever used in an automobile.
As you can see this gets kind of involved.
Yes it sure seems to do that ...... trying to absorb this is getting involved also
I have a question for any or all of you electronics wizards ....
What, if any, kind of circuit could a guy build to reduce a 12 volt charger to charge 6 volts ?
Solar trickle is what I have in mind for a charger.
Thanks for any consideration
