Robert: As you go up in the Crown XLS model #s the higher the power rating, correct? And better specs as well? Your Polk SDA2s are 4 ohm impedance, which most likely means you can see dips below 4 ohms in some frequencies. That is pretty demanding for most amplifiers.
Thanks for the pictures on the unveiling of your Crown XLS1500.
