Currently I have an AT440mla, which features a microline stylus. (Technics SL-1800 TT)
So, far, of all the cartridge types I have ever tried, the AT440mla tracks better then anything I have yet come across, and it is also the most expensive cart I own.
Now, some people do not have tracking or reported inner groove distortion on the Shure M97xe. But I do. This may be mostly due to used/worn records but not always.
Most of the differences that I have found between these two carts are not uncommon however, as I have read over time across the net.
If people are not having any issues with elliptical or even conical styli, could it be a difference regarding issues with different arms? (given alignment is also set properly)
What concerns me is that if I can only get something as good as a microline to perform to my satisfaction, then that would knock a lot of choices off my list, which seems unfortunate.
Thank you.
***I did order a JICO SAS and I appreciate Larry's communication and help on the Shure. Unfortunately it'll probably be at least 5 weeks before I get my order....***
Thank you.
