Timdalf the Grey's WOPL 1000
If someone could correct the pic or give me instructions on how to right them before I upload them, Jase and I would appreciate it.
Timdalf's 700 came back today. Reason? Wouldn't power on, fuse was good , but wasn't making contact. Took the AGX out and put in an AGC and everything is fine. Well, almost everything. A meter hold down bolt came tumbling out after I opened it up. I'm thinkin it fell out on the way over here, otherwise there would be a lot more wrong with it...
Gibsonian
Guess I was confused on the whereabouts of the owner, Mr Timdalf.
I do remember following it some back when you rebuilt it, but haven't looked at it. I definitely will though. Is there anything in particular I need to understand? I just checked and it arrived today so after setting the bias (are the pots labeled on the board for this) and checking DC offset, I plan to stick her in and give her a listen.
No they aren't labeled other than R20. When you pop the top there will be 2 blue pots staring right at you...
