Improved Grounding Scheme on Stock PL400
A member from Central Ohio asked me to conjure up a drawing for an improved grounding scheme for a PL400 that has not received a White Oak Audio main board (why would anyone want one of those?) Anyway, with no other modifications, this would be the improved grounding scheme for a "stock" PL400.
This method separates the inputs by giving them individual paths to ground. It also brings all grounds to a "star" connection to prevent ground loops, and floats the chassis with a reference to ground through a low-value resistor in case of an internal short-circuit. This is as simple as I can make it and still reduce the grounding anomalies; I strongly recommend a three-prong power plug and cord with the long ground wire firmly connected to the chassis so if there is a pull on the cable, it is the last wire to break.
Mark
Mark
