There are many different means and methods to test transistors.
I use a variety of test equipment depending upon whether the transistor is a small, medium or high power device.
A basic Digital Multimeter alone will not tell you whether a transistor is truly "GOOD". Fundamentally, all a DMM can really do is tell you whether you have an open or a short.
A DMM will not tell you whether a transistor is genuine or counterfeit.
A DMM will not necessarily tell you whether the transistor is "leaking" unless of course it is "leaking" a lot.
DMM's with a hFE/Beta function may work ok for small transistors but in my opinion are not suitable at all for high power transistors.
With the input of others and an on-going evolutionary process....... at about the time one thinks they know it all...... along comes another test I now perform that I hadn't in the past.
As time permits, I will begin to discuss the tests I am now performing. I have already shared this information via phone with a few active members in the forum. I hope to one day have a Excel spreadsheet with all the data I will be collecting.
I will end for now, as I haven't had enough sleep.
Ed
