- Jan 14, 2011
- Gillette, Wyo.
Must be those evil coal companies gouging you...
Done....and Jani's checking out the shower now....
Hi temp thermoplastic, sounds like THHN insulation...
The newer low-flow Water Pik shower head must be right in the middle of the preferred rate as it cycles a couple of relays pretty regularly. There is some overshoot on the hot side and slow recovery on the cold side, so the water temp is in a state of constant flux. The incoming water this time of year is 42 Deg so that doesn't help. I heated a lot of water and generated a lot of steam with Hot Oilers in the oilfield and out of all the things we did make consistent temp steam was a bitch, constatly on the controls, so I do understand how hrd this is to do on the fly...
8-30 amp exactly like the ones we use on the 700 relay board. Resolution could be better I think...
Much more than that Lee, I doubt they are banging the relays any faster than 200msec. The Thyristor would have potentially any fraction of an AC cycle depending on the thyristor type chosen.So twice the resolution....
OH..........DAYAM Dude, you know your power circuits don't ya....
I suppose a thyristor that can handle 30 amps AC is silly cheap[ compared to a 30 amp electromechanical relay...
