Stephen's Monster Mono's
#49
It has stalled out. Have the parts for most everything, have some drawings to drop off at the metal cutting place, but time has been at a premium lately...
#50
From what I can unedrstand this is a walkup circuit to minimized in rush. It seems overly complex. Was there any thought to using a phase angle controller like the TDA1185? This chip can be configured as a softstart circuit. It drives a triac. One app I use it for it to softstart the driveway light. The bulb is difficult to change. By using the TD1185 and a triac the light bulb lasts much longer as it doesn't see the sudden turn on.
I've built other types over the years. With todays snubberless triacs they're a breeze to use.
#51
I know little of soft start circuits Don. But I do like the use of HUGE S'S relays where I am flipping the switch on 2 800 VA toroid and 140,000uf of capacitance.
CASSETTE DECK
Kapiti Coast, New Zealand
Path under Coastlands overbridge
#56
This circuit is suitable for less critical inrush current limiting applications and will be suitable for your driveway lights, if the normally open relay contacts are connected in parallel with a surge rated wire wound power resistor of the appropriate resistance value, in series with driveway lights.
A thermal cutout is required for the wire wound resistor in this application.
http://forums.phxaudiotape.com/show...-relay-circuit?p=108224&viewfull=1#post108224
A 12 volt DC power supply is required to run relay with timer circuit. 100mA maximum current draw.
