- Jan 14, 2011
- Gillette, Wyo.
Tubes are a different animal for sure.
laatsch55 said:No these are clear Larrt. The tube swapout helped a lot. Just gotta get the phono se ction quieted down then I'll send her on. The old tubes were a definate part of the problem , heck I can give these new ones a good groping and no noise.
soundude said:heres the amp built for my son, the coolest thing is the brass is a door kick plate from Home craphole (DEPOT), and was cheaper than buying a chassis. but I have the clear top in this amp as the first gain stage, so its sound is just amplified all the way through...[attachment=1:17iwuqa5]IMG_4567.JPG[/attachment:17iwuqa5][attachment=0:17iwuqa5]IMG_4565.JPG[/attachment:17iwuqa5]
soundude said:Larry do you build, got a simple one for 6l6's or kt66's with a single tube on the front for gain and splitter, easy 45watts a channel, and awesome response.
some people don't like dealing with the high voltages so if you are one I understand...definitly hurts if you catch something while its on...OUCH!!
soundude said:Larry, there is no bends, built a wood frane and routered a recess so the plate was flush with the wood edge, brass screws secure it to the deck and hole sawed the controls and routered the holes.
but the whole front end of the amp is all med mu dual triodes...
When I build a system from scatch I like to have stages all seprate from each other, can concetrate on each stage and not worry about noises induced from phono or line stages.
I only like rivets when I use aluminum chassis and going to make enclosure on the amp..easy with rivets but if open looks better with shiny screws....I'm in the process of designing a EL34 amp, with 100w from 2 tubes but the potentials on the plates are 740vdc but the currents are low so the tube can live a decent life without the heat..front end is a pentode and phase splitter is triode..
Larry if you like tubes that much download the Radiotrons Designers Handbook, essential to tubes and loaded with information..I posted link in earlier tread, right off rutgers univesitys site. Think its RDH4 headfonz, google search.
soundude said:Hi Lee, is the peamp quite? I noticed in the picture the nut that screws the board down touches the grounding trace. if you put back together and noisy, try removing the nut..
