Here is the response by the seller with the upgraded SFL-2 pre:
"When I received the SFL-2, the tubes were JJ 6922 tubes which the previous owner already put a lot of mileage on it. My initial experience - the SFL-2 is very quiet; does not sound like any tube preamp I had before...very neutral and very dynamic. When compared to my passive preamp (I have quite a few on hand), the neutrality of sound is actual on par when compared to my Luminous Audio's Axiom Signature passive preamp (with Walker's Mod). That says a lot about the neutral sound of the SFL-2. But it beats my Axiom passive preamp with loads of dynamic and the mid bass is a lot more realistic than all the passive preamps I have on hand.
About a year ago, I came across another gentlemen in the States who was selling his eight NIB Amperex Bugle 6DJ8s and I got them all. I then phoned Chris Johnson and asked for his advice on where (and how many) should I put the 6DJ8 with the best results. Chris mentioned that, to be most cost effective, only 2 tubes will make the most difference (I believe he mentioned LV1 and V1). But he also mentioned that all tubes are interrelated in the circuitry and and the other tubes put into the SFL-2 will also affect the overall sound of it. As such, I replaced the eight JJ 6922 tubes with my Bugle Boy 6DJ8 tubes. Since I am not an expert in fine tuning the SFL-2, I brought the preamp to Partsconnexion in Oakville and the technician over there adjust the preamp to the manufacture's specs. I also have them installed eight brand new Pearl Tube Coolers before I picked them up.
The sound after retubed with eight 6DJ8s.....I would say the dynamic is a bit more enhanced and more quiet. The biggest improvement is in the soundstage arena. I cannot say the soundstage is wider but definitely the sound stage is much deeper (the sound stage is not wider probably due to my Sanders 10C electrostatic loudspeakers).
So you mentioned that your experience with the SFL-2 was not that favourable, sort of mellow.....that is not my experience at all, could that be your friend's setup at that time? As I mentioned, the dynamic (to me) is one of SFL-2 strength and the sound is very neutral...not the classic tube sound at all."
