speakerman1 said:
Ok FF & REV voltage is 5.82 VDC Play is 3.something VDC.
Thanks Again
Larry
Not sure if I have the same kind in my KX-W602, but if it's anywhere close then that voltage is about a volt off - I am reading 6.8 volts FF/REW.
Look close or around the motor for a 8 or 9 pin single line (SIP) I.C. with a toshiba part number TA-7291. Refer to the attached skeezer... pin 2 is VCC (in my case, 12 volts), and pin 8 is the "ref" voltage, which happens to be 6.8 volts. If you don't have the same voltage there as you did on the motor (especially if it's higher), than the IC could be suspect. Check VCC for 12 volts while you're at it - if that's low, then we may be looking back at the power supply.
Note.. I have the 7291-S... if you have a different package like P or F then make sure you reference the right pin in the attached diagram...
[attachment=0:3nc0tfoj]TA7291.jpg[/attachment:3nc0tfoj]
