REW (Room EQ Wizard) Speaker Software
THD+N
Stoneville North Carolina
Has anybody used this? I downloaded it last summer and it is great. Takes awhile to learn, but it seems to be fairly accurate using an old Radio Shack sound meter. There is even a calibration file you can download to make the Radio Shack sound meter perform better than it should. I compared near-field measurements of REW to a Klippell and they are very close. Highly recommend.
It's worth learning if you are into speakers.
JustMike
"wherever she lets me"
"Just Passin thru"
Yep very interested . And I have one of the old R.S. sound meters.
Can you post the Link ? Or just start at the REW forum ?
Thanks posting this.
jM
THD+N
I would start at the forum. I'd go thru set-up with you, but I am packing up to move. It's amazing how much "stuff" I have accumulated.
I thought I was in my "forever home", but life had different plans.
JustMike
"Just Passin thru"
Thanks Nick, I'll start at the forum.
I sure don't envy you on the move Bud, I'm the same way, I wouldn't know where to start .
Take it easy on the way, turn up the tunes.
jM
I've always just build them by ear with some meter readings.
