This would be Part VI or VII doesn't matter really which. The problem was 'Death Grip' IC's, they had the loosen screw collar, but still way too tight. I baby my gear, and had a bad feeling getting those suckers off, sure enough the Input (R) jack got jacked. It's the one far right under the Balanced IN/Outs (those are at the top). if you blow it up you can see the silver pin on top of the black plastic plug is broke, there's some small damage caused by me with a screwdriver trying to bend it back down in place. The jack has the (connect strip??) going down thru the board.
So I don't know if all four jacks need to be replaced as a unit. If it's just a solder job, the other three will need reinforcement, because the may be close to the failure point and not show it. I'm correct in that thought, right? Just a small tug later on could cause another failure.
Crappy camera, sorry!
