Randy's K's AKA Vega Killers
#23
Think I'd be looking for a higher xmax higher and/or power handling woofer with similar T/S.
Are the voice coils burning up or getting mechanically destroyed?
Voice coils Scott, just being over powered. . The Crites 1526C's are modeled after the K-33 woof. A higher power woof wouldbenice if they could match up to the cab...
VSAT88
Phenix City Alabama
Like my BlueTooth ?
#26
I have a few things I have gathered up for a similar set of speakers. Corner horns, I have the corners. I just cannot imagine having just on set of speakers in there though. Just one set that I would listen to all the time. Maybe I will grow up one day. As I said, I am cobbling the parts together. We will see. Very Nice Lee.
Gibsonian
#27
Ok. If I get some time I'll pull T/S parameters from the K33 and see if there is anything similar spec'd out there but with higher power handling.
Skratch
Huntley Il.
#30
Eminence Kappa15C is supposed to work well in K horns and can handle much more power
#33
Was looking on Craigslist today. Lots of very inexpensive thin birch plywood for sale cheap. Nothing thick and more than 8 ply. Thought was, perhaps bonding it to MDF.
I do hate cutting MDF though. I'll continue to watch. Lots of good stuff stuck away in warehouses that gets cleared out from time to time
#35
Mine were built with 1/2 " marine grade plywood.
Scratch built a set of Soniphase S6's for me out of 1/2 Baltic birch I think. Mark , what was that stuff? Too bad you dont have access to that big laser cutter....man...that was some of the best fit I've seen..
Skratch
Huntley Il.
#36
Those were made from 19 mm 13 ply Finnish birch, used in the diecutting industry. The laser was holding tolerance of .002 which made assembly a breeze
#40
11 ply 3/4" birch glued to 3/4" mdf with 2 by 4's running across all sides/ends are what these are built with. Front baffle is 2.25" with birch mdf birch sandwich. These are quite heavy, why I have them on homeade 2x8 construction trucks.
Awesome! The sandwich construction would simplify and aid making the joints overlap perfectly. What a great idea!
