Hello Guys,
I have been a member for a while, but this is my first post. I have met a few of you through the grapevine, and can’t thank you all enough for the help and support.
I am currently installing the WOA backplane boards and the main driver (G1) in a 700b. I have Don’s DC protection Board as well. I have a question on installing the WA DCP board in this set-up. I built the backplanes for full comp, and these have a Zoebel network on each of them. My instructions note to not use the Zoebel network on the WA DCP board, if I am installing the WOA backplane boards, which I am. I am close to assembling everything into the bare chassis, and wiring looks very straightforward, but looking at the WA DCP board, do I simply remove the R10 and R11 resistors along with the C4 and C5 capacitors to “not use” the WA DCP Zoebel Network. I may be wrong, so need some guidance here. I am using my X-Ray machine here, holding it up to a light and following the traces.
Thank You,
V700b
Thank You,
V700b
