grapplesaw
The carver 4000t is way better than most Phase Linear preamps. I have serval throughout the house. The best phase linear had was the model 3500 -3300 but no equal.
Hi Jim,Interested in info on your balanced to single-ended converters, George...
Gents, an update on the GPulseLinear 2000 preamp. Just waiting for a custom made toroid inductor to add to the "Rumble Filter" that is a unique design that does NOT affect the RIAA Curve at all. Not a High pass filter that commonly used and affects the sonic performance at 20Hz! Its a SHARP NOTCH filter centered at 6Hz at -25 dB that removes tone arm resonance amplification. Attenuation starts at 18 Hz at -3 dB, then is sharp past 10-15 Hz at -15dB! When engaged... the speakers totally settle down with no flapping! This IS PATENT PENDING. It really is a game changer using vinyl at super high level. Power amps waste no power flapping the speakers due to tone arm resonances and mechanical pickup. Saves speakers!! The sonic accuracy is totally maintained and accurate with thundering bass! The RIAA curve is maintained at +/- 0.35 dB at full line level output @ 10VRMS unbalanced AND at the BALANCED XLR line level outputs. I'm getting quotes for the special machine wound Inductor. The simulations and pic if the inductor below. Very close to releasing it for purchase. This last minute notch filter is worth waiting for!Phase Linear 2000.
Separate tone and turnover frequencies for each channel, with that beautiful Ambience output for the rear channels.
I did upgrades to mine, and also designed a super better version of it (GPulseLinear 2000, Kit or assembled and tested) from the bottom up. The attachment is a general overview:
Uses "Sound Plus" zero distortion and super low noise Op-amps. Just finishing up the XLR balanced interface PCB this week. Then ordering the front and rear panels that are shown in the attachment. It sounds awesome.
Did you check out Wyn’s “warp filter”? He’s doing this with off the shelf parts. (I hate what he named it but that’s exactly what it is)
I understand your enthusiasm but custom parts can cause problems.
As I understand it Wyn’s design is based on similar control circuits used on the cutting lathe. And it also stops woofer excursions outside the audible band. Several of the builders have “special” records that beat the woofers and now they’re playable. Some videos were posted and you can see those cones going!
I don’t have any records in that condition but I do keep it engaged all the time. I see no reason not to.
I don’t have the ability to compare your two designs technically but empirically they do the same job and his is simple and cheap.
I’m just trying to keep you out of the weeds with custom parts and their expense. We all know the joy of finding unique parts 40 years later…
