Everything on the back wall is measuring good. The only thing suspect is the one on that far right driver that I posted a pic of. It's not reading the same as the other 3 that didn't get hot.
I need a picture of a bare PL 14-20 Rev. E control board or a schematic so I can check the resistors you listed. I can't see the numbers on my board.
I do know that D13R is broken in half. Have not checked any of the resistors you listed yet.
Is there a check on the two op amps at the top of the board? I was getting different voltages between L/R when I had it powered up the last time.
I have the control board off now.
PM me your email and I will send you the complete doc pack since you acquired these from another. He got the doc pack, you didn't.
One of life's mysteries to me is the Phoenix connectors. When I ship them with the kits, I interlock the tiny dovetails so it is like one solid connector. This must have been an aftermarket procurement and the guy did not know that they interlock. These connectors are a thing of pure German precision the way they lock together.
On the drivers, you only need the special drivers in the second and fourth column when counting starting at the transformer end. They are needed in the PNP quasi configuration only for stability. The first and third columns can be MJ15024 or MJ21196 transistors since that configuration is straight NPN emitter follower. The broken D13R is not doing you any good and is likely an artifact of the misplaced ground wire, too much current flowing through that poor small signal diode.
There is no check you can perform on the op amp, they are seldom a problem.
