Hi all,
Thanks for your help getting my two series 2 PL300's running again. I'm starting a new thread to keep things on topic.
I acquired a PL400 about 6 months ago and this weekend I finally found the time to replace the filter caps and install the Watts Abundant relay. Bias is normal and It came up fine on a DBT, has normal DC offset, and is dead quiet when connected to speakers but no source. I have tried connecting two sources, a laptop and a miniDSP 2x4HD with optical input. One is battery powered and the other is powered by a 2-prong wall wart. I am getting loud 60 hz hum with both sources but here is the interesting thing: if I touch the case or the power cable of the miniDSP with my hand, the hum goes away until I remove my hand. If I UNPLUG the miniDSP power, the amp still hums. The PL300s didn't give me any problems with noise using the same source. Tried three different known good RCA cables.
The RCA jack grounding scheme is exactly as specified in the Watts Abundant instructions: cut of all but 1/2" of the thick, bare, ground wire from the RCA jacks, clean off oxidation w/ a pocket knife and then solder a white wire to be run from the RCA ground along the bottom of the chassis to the filter capacitor ground bar using a solder-on lug provided in the kit. The relay board is grounded to a terminal strip much closer to the board as specified in step 24:
https://wattsabundant.com/sitebuildercontent/sitebuilderfiles/400_Installation_Procedure.pdf
I did some searching on this forum and found one related thread:
https://forums.phxaudiotape.com/threads/pl400-ground-loops-and-hum.8292/
Sounds like a grounding problem to me, but I'm not really sure where to start other than opening up the chassis and poking.
