PL400 Assembly Process Slide Show
Hopefully this will be helpful to WOPL builders. This is a build conducted with all new materials except the transformer, meters, faceplate and 8 fin heatsinks which have been reused.
This PL400 Backplane build utilizes NTE192 bias transistors, not the usual 2N5088 transistors we all use. This build type is a qualification build of that bias transistor type as a contingency should we run out in the future (I have a lifetime supply of 2N5088 transistors :-))
PL400 Complete Rebuild Slide Show
This PL400 Backplane build utilizes NTE192 bias transistors, not the usual 2N5088 transistors we all use. This build type is a qualification build of that bias transistor type as a contingency should we run out in the future (I have a lifetime supply of 2N5088 transistors :))
I have a few too Joe....along with 42's 651's, 751's....a lot of those...
looks good Joe
I like that bridge Rectifier board. it really cleans it up ;) so much easier to install to.
I'm also doing something similar to the RCA inputs , still going to solder the nuts in and I have a wire that under the nuts and is lifted it up between the 2 so I can easily solder the wires. I'm done w that puddle of cold solder (have plans for the other puddles on the bus bar to)
Great pics and a very clean build that will inspire many to do the job correctly.
I never realized how much more space your WOAD chassis creates.
that rectifier board is the ultimate finishing touch in any WOPL build!
Can't open it with Android, says wrong file type. I'll check it out on Windows.
Joe,
Love the frog!
Is the Bridge Rectifier Snubber Board something new?
It really cleans things up. I have drilled extra holes in the prongs on my 700b builds.
Really nicely done!
Joe,
Love the frog!
Really nicely done!
I heard you and others say that so I invented this to solve for that and to clean up that area. Glad you like it. One of our standard offerings now
Very Nice,
Another WOPL "touch of class".
Greatly appreciate that you are " Always working on making it better" !!!!
Thank You Joe.
