- May 14, 2014
- Southwest Kootenays BC
I thought I'd be buttoning up the amp tonight.
The unused board was mounted, connected and worked in this 400 amplifier about a month ago. The face plate has been off and meters disconnected ever since awaiting the install of a new light board which I did today. Ironically, I just bought a variac and this was the first time I used it. Part of the delay was waiting for the arrival of some white LED's to replace the blue ones which I received yesterday.
All went well, the variac brought the amp up to power and the LED's illuminated. Before putting on the face plate but after attaching the meters, I thought to re-check the bias once again. The amp was powered up for 30 or so minutes then turned off as I connected the DMM for left channel bias check which was a bit low so I adjusted to 350mv. Turned the amp off again, attached DMM for right channel bias check, turned up the variac and as I waited for the reading to stabilize, heard a noise and witnessed a fair bit of vapor being released. The tops of C3L & C3E had opened and vented.
I assume that replacing those two capacitors is not the answer unto itself. Anyone know what may have gone wrong?
