PL 700B Faceplate
TMZ2
Michigan
Sorry if this is in the wrong section.
I'm looking to see if anyone has ever disassembled the lens out of the PL 700B faceplate and if so if they could post some pictures of the front and back of the face plate with the Center lens out. Thanks Tony
The lens is just glued/taped on Tony. If you need any other info, I have several here that are Lee's
TMZ2
Michigan
Do you have any there with the lens removed that you can take a picture of the front and back ? Just wondering if there's any machine work in the front or back of the plate to recess that centerpiece in. Thanks
He has a couple flamers/beaters here, I will take some images for you Tony
Looks like the middle area where the plastic and blue backing is recessed slightly so the plastic will sit level with the faceplate without sticking out. Ignore the little hole above, it's not factory. Handley drilled it to put a light there
The meter bezels overlap that area to hold the plastic piece in also. The plastic is as big as the metal piece you see but the backlight only goes through the small opening you see on the back
TMZ2
Michigan
Thanks so much for doing that for me. Now time to do a little studying and see what I can come up with. I'll come up with something later today and see what you guys think.
Looks like a 1/16th of an inch recess Tony (or thereabouts). If you need any measurements, drop me a PM
Here is the width for now
It's one of the original Aerosmith tour amps, it had a rough life with Steven Tyler screaming through it
gadget73
If you ever happen to need measurements or pics of a Pro 700 faceplate, let me know. They are slightly different than the other 700 series faceplates. May not be much of a demand for them though, I think I own the only one on the site here.
TMZ2
Michigan
I will keep that in mind thanks so much for the offer.
TMZ2
Michigan
AI should've posted one of these along time ago made a first run and they were all gone made a second run and here's a quick picture just sent this on the unit real quick haven't had a chance to really put everything together and lighted up. Will post some better pictures later on when I get a chance to actually get it all together.
TMZ2
Michigan
I can't answer the question about the meters I'm more of a Marantz guy but do like the look and the sound of the phase linear maybe one of the other guys can chime in and help out there.
Here's another pic.
Now which 700Bs have the meter range 0 20db and which ones are 20 0?
Doug, Ed and I discussed that awhile ago. I don't remember if there was a hard and fast rule to determine which it would be. And there is both silkscreen versions out there. I believe there was some discussion on whether the meter range switch could be reversed to conform to a different plate....and I can't remember the conclusion of that discussion. I'll call Ed tonight and check that.
yeliab1
Southern Indiana
Too much is just about right
Black face plates
Who is supplying these face plates? I'd sure like one for my B.
Thanks
Here's another pic.
