PL 400 Series One Fuse holder replacement
Sunnbobb
Mount Vernon, WA
Bikes, baseball and big amps.
My 400 has three different fuse holders.. I searched the site and the net for information on a proper replacement part. I'd like the holders to match and be original if possible. Anybody have a suggestion? I appreciate it.
Thanks, exactly what I needed. You're a good man Charlie Brown.
Don't tell anybody, I might get a bad name.
I buy those holders by the 100's since I replace every single one on every amp I have done and these are great hevy dooty stuuf.
Looks like they chinee'd out a bit but still should be excellent replacements. The new style tabs are for either spade terminals or wire so no problem there. Looks like the 16ga wire should go in there easily. I have used these before.
Funny, I didn't realize that they have a store on the south side of the Twin Cities.
They also carry the solder style with tab's like your older ones.
