- Apr 28, 2015
I just acquired a 3300 preamp and set it up to test all the functions. I used a known amp and known speakers, then played a CD through all the inputs. However, even though the music seemed to play fine, when I took the grill covers off, one of the woofers was pulsing, waffling, or traveling extremely far, back and forth, seemingly on its own, and through all the inputs. The other channel was fine. I did everything necessary to determine that the problem is coming from one channel on the pre, but I don't know where to start to look for the cause. The woofer waffles this way even when the volume is all the way down. It may be pulsing to the music that's being played, but I can't really tell. Another weird thing is that the power light stays on as long as the unit is plugged in. It never goes off until the pre is unplugged. Yet another thing is, I can't seem to get the headphone jack to produce a signal, regardless of whether I use Switched or Unswitched. Any ideas?
