Phase linear series II 200 speaker connection problems?
oldphaser
#21
Ed I just looked at it and found it is a complete B series 200. not sure if that one is any good.
Perry,
The Phase Linear 200B is a cheaper version of the 200 series 1. Essentially it is the same as a 200 series 1 minus the LED display.
Ed
yup, once the fine finished factory surface is gone, it's just a matter of time for the relay contacts. Remembering the old days of filing points on the hot rod. Once they were dressed, it was time to start shopping for a new set. Under a microscope they have tiny imperfections after filing or sanding and the current just eats them up and leaves carbon. not good for much....
Any recommendations on a replacement relay? What kind of amperage should the contacts be able to handle for this (120wpc) amp? I'm thinking of an octal-base plug-in relay and socket, there's plenty of room in the chassis for that. Thoughts?
Charles.
#29
So is mine, nothing else will do so far.....
Debbie said that today. She wants a bedroom system but she does not want a giant set of speakers :roll:
No giant speakers... no WOPL for you
I would love to find her one of those Proton amps with the big meters and she could use the Infinity RS1 book shelfs I have
#30
Charles.
10 amps would be plenty and a LOT of relays out there with that rating...
oldphaser
#31
Charles,
Are you looking for a relay for a Phase Linear 200? If so, I have a supply of new old stock relays.
Ed
