Phase linear 700b transistor replacements
Slake
Hello
I am a new member to this site and this is my first post. I have been collection and repairing vintage audio gear for 15 years.
Yesterday I purchased a non working Phase Linear 700b (Serial# 2555). I believe it is a series 1?. The current transistors are 2N3773’s Motorola’s as the main 20 transistors. I read in the phase Linear service manual that the 2N’s were not a good choice.
My questions are :
1) what are the best transistors in 2025 to replace the main 20 with.
2) it appears the original design called for 4 other transistors, what should these be replaced with?
thanks for the help
Bob
MJ 21196 on the 20 anf RCA 410'S as drivers..
I second what he said, with the exception that "anf" should be "and". Sorry Lee, you were 99% correct. The RCA 410's (located at the bottom of each heat sink) are a must for stability. Mj15024's can be used for outputs. See service bulletins in attached manual
Hello
My questions are :
thanks for the help
Bob
Didn't know there was a 700B Series 1 or any other "Series" . There were only the 700 (original with the split face and tiny meters), 700B (big analog meters), 700 Series II (Cylon meters). Got a picture of that 700B Series 1???? We love the 1 of a kind amps. There were a couple of off the wall specimens but I never seen an amp marked 700B Series 1
