Phase linear 700b transistor replacements
Slake
Hello
I am a new member to this site and this is my first post. I have been collection and repairing vintage audio gear for 15 years.
Yesterday I purchased a non working Phase Linear 700b (Serial# 2555). I believe it is a series 1?. The current transistors are 2N3773’s Motorola’s as the main 20 transistors. I read in the phase Linear service manual that the 2N’s were not a good choice.
My questions are :
1) what are the best transistors in 2025 to replace the main 20 with.
2) it appears the original design called for 4 other transistors, what should these be replaced with?
thanks for the help
Bob
MJ 21196 on the 20 anf RCA 410'S as drivers..
I second what he said, with the exception that "anf" should be "and". Sorry Lee, you were 99% correct. The RCA 410's (located at the bottom of each heat sink) are a must for stability. Mj15024's can be used for outputs. See service bulletins in attached manual
Hello
My questions are :
thanks for the help
Bob
Didn't know there was a 700B Series 1 or any other "Series" . There were only the 700 (original with the split face and tiny meters), 700B (big analog meters), 700 Series II (Cylon meters). Got a picture of that 700B Series 1???? We love the 1 of a kind amps. There were a couple of off the wall specimens but I never seen an amp marked 700B Series 1
Slake
Ok, so Phase linear made a model 700, 700b and 700 series 2. So my plan is to rebuild my 700b. It sounds like I have 2 transistor options that are readily available, MJ21196's and Mj15024's each with the RCA 410's as drivers. Is there an advantage of one over the other or are they equivalent?
thanks
Bob
thanks
Bob
MJ21196G devices are the top of the heap with the best SOA in the ON Semi lineup. 15024 are OK but not SOA rated as highly as the 21196 devices
