Phase Linear 4000 Resurrection
Geezer
#41
I may need some help in determining that from my meter? I put in a signal but there was no passthrough of signal... just a sine wave goes in but none comes out. IIRC, per the service manual there was a signal using the tape monitor, but no signal at all at the output of the preamp.
I will get to reflowing all of the ones on the main board soon I hope... and dig into the service manual. This thing is too cool to pass along for parts!
#42
Well, you didn't say that you looked at the output with the scope or how you were actually troubleshooting with the book. or if you were just poking around without a plan (or with a chopstick). If you are not using the book to correctly troubleshoot a unit, it's a crapshoot and I'll defer to the guys with patience.
#43
Too cool to pass along for parts yes.....but you're gonna get tired of working on it..........i'll bet on it....
marcok
Milan Italy
#44
-Remove all boards
-Insert tone board and logic board after cleaning their connectors .
-Correlator , peak unlimiter , ambience , equalizer , tone , tape monitor in out position .
-Use aux input and check again .
In this config it's only a 15 dB line amp .
Ciao
Marco
#45
-Remove all boards
Ciao
Marco
Then when it works for 5 minutes and dies, rinse and repeat until you get pissed and send it to Davy Jones Locker.
Geezer
#46
Thanks for your help WOPL Sniffer... have only been able to get a peek at this thing for a few minutes here and there so my approach has been scattered rather than anything close to methodical. I will come back after I've finished up my other project, SM in hand and get going on this thing.
