- Jan 14, 2011
- Gillette, Wyo.
600....but don't dwaddle...wet the tip of the iron before contact...
That gave me a flash image of licking the tip like some do a pencil before writing with it.
600??? Is yours nuclear powered?600....but don't dwaddle...wet the tip of the iron before contact...
We use C in Oz. Didn't think of F 'til after my panic attack...[/QUOTE
Yeah man, on the left is the "Old School" Weller Expert 100/140 watt, on the right are two 200 watt irons, the red handle was made by Hexacon of Roselle Park NJ, the black by American Electrical Heater of Detroit. The Weller handles the bus bars nicely.Temperature does not indicate the power of the iron to heat a large mass of metal. My 15 Watt soldering pencil heats to 750 Deg F, but wimps out on anything larger than 16 Gage wire.
Check the power rating, should be 40W or 60W for what we do. I have an old school large iron for the buss bar, it is 200W. Whether you use 120V or 240V, Celsius or Fahrenheit, the wattage has to be adequate for the job.
Once you have sufficient power, you can adjust the temperature to work with the solder you have selected. Always use the lowest temperature that will flow the solder, typically between 600 and 700 degrees F will work.
The 200 Watt iron I have is a Craftsman with a cloth covered cord. It looks exactly like the black handled iron you have and was probably made by American Electrical Heater of Detroit, back in the day when Detroit put out some good iron.the black by American Electrical Heater of Detroit.
Yes, indeed! Plug it in, walk away and do something else while it heats up! I've used them for making battery cables for cars, but it's easier and faster just fire up a butane or propane torch. They were used by my father doing Fairchild C-119 (The Flying Boxcar) electrical work.The 200 Watt iron I have is a Craftsman with a cloth covered cord. It looks exactly like the black handled iron you have and was probably made by American Electrical Heater of Detroit, back in the day when Detroit put out some good iron.
That iron takes forever to heat up (and cool down) but I bet I could start a Saturn V rocket engine with it!
Oh yes, I have one of those also. Inherited it with a bunch a ancient wood working tools and carpenters box from a great, great grandfather who worked for the railroad as a carpenter back when railcars where made with wood sides.I remember these from High School Metal Shop back in the 60's.
Always wondered how they heated those up, coal fire in a cast iron stove or acetylene torch I suppose. How did you do it in school and what were you soldering?
I now remember seeing those little furnaces back when I was a kid, I just forgot about them. So that's what they were for! I remember old tinwork that was soldered together and how lead poisoning was a new "thing" to be aware of.We used a mini gas fired oven/furnace type thingie. I just can't remember what it was called.
It was brick or clay lined with short legs to keep it up off the bench.
Similar to this:
Yup, thousands of $. This next weekend when I'm home I'll post some photos of the box and tools, it's huge. Most everything one would need to build a post and beam or log cabin. Several planes in it, but they are very primitive. Not like the British made ones that are ornate.Have you seen the prices some collectors a paying for old wood working 'planes'? Thousands!
I saw a segment on a collectors show recently and this bloke had hundreds and hundreds of 'em.
I'm [was] a 3rd generation Railways man. My Grandad, Dad and me.
Lead was everywhere when I was a kid. It hadn't got it's bad rap yet.I now remember seeing those little furnaces back when I was a kid, I just forgot about them. So that's what they were for! I remember old tinwork that was soldered together and how lead poisoning was a new "thing" to be aware of.
