Phase linear 3500
philinear
Hi,
I'm currently recapping a 3500 phase linear preamp.
Are there any interesting mods or upgrade to be done on this unit?
cheers
It has more in common with the 3300 than the PL3600/3800. Complete different pedigrees....
philinear
ok, thought it was more like a 3800. Didn't start quite yet, that's why I wanted to know if there was some improvement to be done on it
I get from an ex Phase Linear tech that the 3800 shares the same electronic as the 3500 so here's the schematics. It definitely looks identical
Couple of points Lee
5532 and 5534 should not have +/-20V powering them. Theyare probably only saved by the 100 ohm resistors in series with each supplyline feed. They are meant to run on +/-15V.
The 5534 is a decompensated amp and hard to get a replacementfor.
The 5532 is easy with an OPA2134 once you fix the +/- 20V supplyproblem.
That is easily fixed with a couple resistor value changes.
Change R2, R3 from 1.82K to 1.33K
Z1-Z4 to OPA4134.
The way this is done by design degrades crosstalk between the L/R channels. Nothing you can do about that.
<strike></strike>
