Need new speaker posts for 700B
62vauxhall
Southwest Kootenays BC
I believe I've found the source of this niggling, intermittent issue with my 700B. Since the WOPL conversion, every so often, the right channel would quit and I've had a merry old time finding out why.
But I think I overlooked the obvious.
I have banana plugs soldered onto my speaker wire and it seems after all this time, one plug is too loose in one of the PL's jacks. I noticed a long time ago the banana plugs don't go into the jacks very far but they seemed secure enough to not concern me.
I can cut the plugs off and replace with spades I suppose but dammit, I like my bananas!
So Before I go to the shops and buy some or order from Mouser, is there a size dimension or spec I need to know about?
Since the amp had the Watts Abundant speaker protection board and it bolts onto to the speaker posts, I thought that might dictate what I should get.
All Mouser Part Numbers.......
Binding post-white----530-111-0101-1
Binding post-black----530-111-0103-1
Binding Post -Red-----530-111-0102-1
They make expandable bananas that are threaded with a center point that extends the 4 center segments for a decent lock..
62vauxhall
You know - if you play with your banana it will expand. :shaking:
Really - if you place a small flat blade screw driver between the mating segments of the male jack and pry them up a smidge you can expand the contact region.
Yes, I did that but these plugs are of the uber cheap variety and even after bending, the one still feels a bit sloppy.
62vauxhall
I've seen those. Not cheap and I dismissed them as a gimmick for the tweakophiles. Looks like there's some merit to the idea after all.
