62vauxhall
- May 14, 2014
- Southwest Kootenays BC
I believe I've found the source of this niggling, intermittent issue with my 700B. Since the WOPL conversion, every so often, the right channel would quit and I've had a merry old time finding out why.
But I think I overlooked the obvious.
I have banana plugs soldered onto my speaker wire and it seems after all this time, one plug is too loose in one of the PL's jacks. I noticed a long time ago the banana plugs don't go into the jacks very far but they seemed secure enough to not concern me.
I can cut the plugs off and replace with spades I suppose but dammit, I like my bananas!
So Before I go to the shops and buy some or order from Mouser, is there a size dimension or spec I need to know about?
Since the amp had the Watts Abundant speaker protection board and it bolts onto to the speaker posts, I thought that might dictate what I should get.
