Replaced Capacitors in the Nakamichi 480. There was no way of telling which way around they went, so the ones which had the label pointing up went in the same way, and vice versa. Still wont erase or bias tape.
Hi Derek, if the transistor replacement still not fix your deck, check the resistors (especially the power ones) on the bias oscillator.
That was quick work, Derek. If it was just a nudge that knocked the resistor off the board, it may have been loose before the capacitor replacement.
Nnado.
Dreaded tape drop-out - I haven't had a cassette malfunction in that way, yet. However, I don't record as much as you do, Derek. But soon enough I will have a tape go bad on me, and most likely towards the end of my recording session. That's why I like to monitor all my recordings with headphones as I am making them and follow up with at least one complete playback through my system speakers at a decent volume.
I may add another Nakamichi deck to my system. I want one which can take over regular duty from my Esoteric deck. It's good to hear your 480 is in active service, now.
.It happens to me too sometimes to notice dropouts when re-recording some chromes from BASF or typeI's, this will not happen with SA's from TDK which are very suitable for repeated re-recordings... Some tapes simply don't like to be re-recorded.
The EXTRAII's are still not pure chromes, Derek. They are 85% chrome and 15% ferricobalt as i remember, i tried to re-record a very old chromedioxide of them and i simply ruined it, the tape is fine like new but it simply doesn't accept a new recording no matter what i tried.
