Miles Davis 180g LP, new pressing thoughts
I have DDEs and I think DTIs. Look up what they mean. Plus I have Power supply 4s. I'm digging as we speak. I found a DTI Pro. I have more in my sound room.
Larry
I have one DDe 1.0 that I put broken on. I'll have to check it. Can you work on things? If so if you fix this one you can have it. No schematics.
Larry
I appreciate that but I'd end up adding it to the pile of other things that need to work on lol.
Sounds scary lol.
On a different note... I thought the guy that I got my TT from striped the single screw that holds the cartridge in. I thought it was a little loose, as I didn't think there should be the faintest rattle when tapped with a fingernail.... So when I pushed on it, it would temporarily tighten. Little did I know, the damn screw was just pushed in. I had to reseat the cartridge so that the screw would go all the way in to meet the threads. THEN I could tighten it. The head of the screw was sticking out the whole time, when it was really supposed to be flush.
No wonder. Naturally, everything else "tightened" up.
