Match the sample with the cassette!
Here's a little blind testing for you. I have recorded 7 completely different cassettes with a sample from Dominic Glynn's Doctor Who Gallifrey One Remix track, around 45 seconds long.
They are all recorded on my NAD 6100, with the Fine Bias set to -1, and the Normal/CrO2/Metal switch set according to tape. All tapes have been previously used, but don't have significant wear.
Peak levels are +5, you can assume that the loudest samples' peaks are that on the deck. Had to slightly turn down the Line In in order to prevent clipping.
These cassettes are:
A. TDK SA90 1994-1997
B. TDK A60 1988-1989 (Cheaper tape mainly for dictation)
C. Memorex Chromium Dioxide 90 (Sponge Pad) 1976-1981 (exact year unknown)
D. BASF Chrome Extra II 90 1988-1989
E. BBC "Retired" Spoken Book Tape, around 90 minutes long (9 pence from Tapeline, cheapo ferric)
F. Maxell XL-II Epitaxial 60 1985-1986
G. Sony HF90 1990-1992
You can find the samples in this DropBox folder.
The samples from the cassettes are called Sample1, Sample2, ect.
The sample taken from the 320Kb/s MP3 is called Master (no pun intended).
Just post your idea of what sample is what like this: 1-A if you think Sample1 is the TDK SA90 tape.
Can you tell what tape it is what? I am looking forward to the results!
eidoscognitio
I failed!
Pretty tricky... Can´t tell without some tools.
By ear, and using a M-AUDIO Project Mix as a playback soundcard and AKG MKII k240 Headphones as output reference, I "dare" to say that:
Sample4=E
Sample5=B
Sample6=G
Other than that... Can´t tell...
( I failed )
Australia
This is certainly a tough one, the Nad 6100 deck does well with adapting to different types of tapes.
Anyway I'll have a stab in the dark, spent around 15 minutes going through samples and deciding:
1-F Maxell XL-II Epitaxial 60 1985-1986
2-C Memorex Chromium Dioxide 90 (Sponge Pad) 1976-1981
3-G Sony HF90 1990-1992
4-B TDK A60 1988-1989 (Cheaper tape mainly for dictation)
5-D BASF Chrome Extra II 90 1988-1989
6-E BBC "Retired" Spoken Book Tape
7-A TDK SA90 1994-1997
Australia
Can you please PM me the answers to make it fair on the other members, I'm very curious =).
